Tree-stand/tunnel project
I had started an in-process description of this project in the wooden structure thread back in November, but never finished it when the site temporarily went to vapor. I thought I'd finish it, maybe moving it to the paper/cardboard forum. It's a composite of many materials, and I have since identified a number of issues I ran into along the way. So here it is, a bit of a repeat, but carried to the end with maybe a few more details left out earlier.
After I built the castle-tunnel project a couple years ago, I had an idea for a second version that would serve as a tree-stand for a small artificial Christmas tree. It too would have a tunnel running through it for an O-gauge train set, either mechanical or electric. So this past fall, I got the itch to give it a try. I took a few photos to document the process, so I thought I'd share those here. I made a few design mistakes along the way and I'll disclose those here in case anyone wants to take a crack at this. I tend to be a stream-of-consciousness style designer/builder, so that catches me up every once in awhile :lol:
The castle was built on a straight tunnel, but I knew the tree bit would have to be in the center to maximize the support. The best way to do that seemed to be to build the tunnel on a curve, than put the tree-stand support at the center. By doing this, I could keep the dimensions of the project to roughly twenty inches square. That would work well with the table I planned to use.
The first step was to build the base. I used similar components as before (1/4-inch plywood for the base, 1x6 pine for the "portals"), although this time the tunnel would be on a 13-1/2 inch radius (same as O-27 gauge), which was also the same radius as the Marklin clockwork track I have. I cut the tunnel portals 3-1/2 inches wide (a quarter-inch wider than those I used on the castle project) and 4-1/2 inches tall, slightly arched at the top. I then screwed the portals to both halves of the base, leaving me with something fairly rigid to work with. I had used a couple sections of O-27 track and a small freight car to come up with the dimensions. This was my first mistake along the way; the tunnel proved too narrow for a couple of my small locos and cars to pass through without rubbing against the interior walls. If I do this again, the tunnel dimensions will be enlarged a couple inches in width and maybe a half-inch in height (at least).
I used USPS corrugated to form the interior walls. I cut it so the corrugated "grain" ran vertically. This allowed me to easily bend the cardboard on a curve to form the walls:
I couldn't figure out a way to make a tunnel ceiling easily, given the combination of the arch and the curve, so I left that off figuring the planned wood top would form a ceiling of sorts for the tunnel.
The next step was to make the tree-stand support. I cut a bunch of four-inch-by-four-inch pieces and glued them together in a stack. Once dry, I glued the stack to the base and added a couple woodscrews from the bottom. Once that was in place, I cut a top from a piece of scrap 3/4-inch birch plywood I had in the shop, than screwed that down on top of the block tower and the tunnel portals. I then drilled a one-inch hole down through the top into the tower about five or six inches deep. I tested the bottom section of the tree in the hole to make sure it fit and that it was not prone to tipping over. I then cut a second hole in the top to pass the cord through, then a notch in the base for the cord to exit (that was my second mistake...should have been on the back side of the "mountain", not the front):
I let the whole thing dry for a couple days, then proceeded to scenery.
Re: Tree-stand/tunnel project
My method of adding "mountain" scenery is similar to that used by many model-railroaders; it's a process of cutting and adding partitions in the profile of the slope, then covering them with either plaster-soaked bits of paper towel or the old school process of papier-mâché. Lionel had a method using sheets of glue-soaked felt, but I've tried that and it's a terrible mess. Howard Lamey turned me on to the time-tested method of papier-mâché, and it gives a good, albeit somewhat fragile, result. It's not too tough for someone to poke a hole in it in a moment of over-exuberance. On the layout, I've used the plaster method, but here I want something fairly lightweight, so we'll be using papier-mâché.
I used more USPS corrugated for the partitions, as the stuff is thin, strong, and lightweight. It's just a matter of making them a uniform height, than cutting them in random patterns and gluing them in. It's a bit tedious, but once you get going, it goes pretty quick. I cut all of the slope bits first and glued those in place; than I cut a bunch of pieces for the top to give that some shape, not just a big flat plateau. I wanted to add a couple of small buildings on the inside part, so I cut some notches in the sloped partitions to accommodate those. Here's where that step ended up:
Most would just go ahead and start covering it at this point, but I find that the partitions show through a bit too much for my taste if you do that. One way to mitigate that is to stuff the cavities between the partitions with balled up paper, but that is a mess and adds quite a bit of weight, especially if you can't pull it out afterwards because you don't have access from behind. I prefer to add a bit of webbing using small strips of paper. This is tedious too, but again, it goes quickly once you get your groove on, and it will help prevent some of the ridging that occurs otherwise. This is where you end up when this step is done:
The last step before papering was to add the basic wall-structure of the two small buildings. I used a few scraps of framing matt board to cut out the pieces, including window and door openings. One I gave some crenulation at the top, perhaps a tribute to the castle project:
Once those were in place, I was ready to paper.
My papier-mâché process is pretty straight-forward. It's basically the same one I used in high-school art class, only I've substituted diluted white glue for the old wheat paste we used back in the day. Also, instead of torn strips of newspaper, I use small pieces of torn paper grocery bags. First I tear up the bags into small two-inch-by-three-inch pieces, then I mix up my glue (one part glue to two parts water). It's super important to tear the bags up into pieces; don't cut them. You want that fine feathery edge when you start applying the paper; it gives you a nice edge to blend/mesh together as you layer the hillside.
I papered the center section first (the part with the two buildings between the tunnel portals), then the section across the back. Carefully butt the paper around the base, to the portals and building walls, then up and over the top edge bit. Put a little diluted glue on your fingers and go over any rough seams, add a few patches to thin spots as necessary, than leave it to dry for a few hours (best overnight). It looks like this as you're finishing the papering process, before it's dry:
When it's dry, it will return to a light color (the paper bag material will be dark when wet). If you see any gaps or tears, you can carefully craft a patch and apply it using a bit of paper bag and some glue. Then you have to let that thoroughly dry. The next step is to detail your tunnel portals.
Tunnel portals came in all sorts of forms and materials. I like the look of cut-stone masonry, so for this, I've unashamedly stolen Howard's methods. I cut a bunch of approximately 1-1/2" x 7/8" pieces of thin corrugated, then fold them in half. I trim one end to match the contour of the abutting hillside, then glue them onto the portal in "L" shaped over-the-corner pieces. You want it rough and somewhat irregular in shape, but also in "courses" as best you can. Use your imagination. When done, I ended up with this:
I let this dry thoroughly, then prepared for the fun part...painting.
Is this fun or what?
Okay, once absolutely dry, I was ready to paint. The painting process would be in two steps: (1) the overall mountain, then (2) the detailing of the buildings and the tunnel portals.
For the overall mountain, I used a few cans of flat or satin spray paint in green, tan, brown, gray, and white. I started with green around the base, than a mottling of green/brown/tan/gray going up the hillside. The top third of the slope and the entire top I sprayed white, trying to achieve a snow-capped mountain effect. There was some overspray on the building walls, but not much, and no worries as it's going to get hand-painted anyway. I gave the stone portal masonry a hand-painting using some gray acrylic craft paint I "borrowed" from the wife's stash. I left the joints between the blocks the lighter color for contrast:
The last thing to do in this step was detail/paint the buildings. They looked a bit drab, so I tried to think of things to do to dress 'em up. The one with the crenulated roof line, I added a strip of basswood around the top to look like a cornice or a ledge. I then gave it a couple coats of some salmon-colored craft paint (same source), followed by a couple coats of yellow for the smaller peaked-roof house.
One of the neat things about the the prewar Lionel tunnels was that some included both interior lights and small buildings on the exterior. There was a hole in the felt or the sheet-metal that allowed s a bit of the interior light to shine through, illuminating the windows of the small buildings. It's a neat effect if you're lucky enough to have seen one. I attempted to replicate the effect here by leaving an opening behind each building and putting translucent vellum paper in the windows. The mistake I made was not leaving easy access to the interior for an interior light. A string of mini-lights/LEDs would work, with the battery box on the outside to turn on/off. But I digress.
I've made a window pattern in Excel that I use to print windows. I've tried a number of different sheet-plastics and papers for printing them, but vellum paper seems to work the best. It's printable, it's translucent, and it's reasonably durable. I printed a couple sets along with doors, cemented them in, than made a roof for each. Since this is a Christmas themed project, I added some "snow" effects.
The last thing to do was to slather the whole thing with glitter. With Howard's help, I've developed an understanding of how best to do this. First, go with a coarse grade of material, not the fine stuff. Second, make sure you use white glitter; some of the stuff sold had green or pink bits in it and it doesn't look great. A nice course, highly-reflective, white glitter seems to work best. I painted the entire tunnel structure with undiluted white glue, then sprinkled it liberally with glitter. After a few minutes, I dumped off the excess, then sprinkled it all back on again. This I left to dry for a few hours. Once dry, I dumped off any remaining excess, brushed it lightly with a brush to knock off any loose bits, then called it done:
Fun project. Here it is in the village display:
On to the next...
I tried running my smallest electric set, a prewar American Flyer, through this thing and no dice, it's just too narrow (as some had warned). So now I'm looking at making another one...ugh!
After a couple of years to think about it, I've decided to go forward with a second version of this thing, one that will hopefully correct the issues we discovered with the first one. The biggest problem was that the tunnel, as some warned, was too narrow. Some of the cars had significant overhang that would scrape against the liner, making transit difficult. The design of the portals, liner, and interior supports will have to be redesigned/widened.
I like the look of a tunnel liner. In the first version, the liner went all the way through. On our basement layout, the tunnel we built includes liners that only extend eight inches or so...the rest of the interior is open. That might be the optimal approach here as well.
Stopped at Lowe's this AM where I picked up a small two-foot square piece of 1/4-inch plywood that the base halves can be cut from (amazing how expensive lumber has gotten, again). I want to make the curvature such that it will accommodate 27-inch diameter Lionel track, as well as 29-inch diameter Märklin clockwork track. Just a one-inch difference in radius, so it should be do-able:
I think I have some scraps around here that I can use to cut the portals and the interior supports...looking around.
Made some progress on the tree-stand project overnight:
I expanded the tunnel interior dimensions by an inch (additional half-inch of clearance on both sides of the track). Ran a Bing clockwork coach and locomotive through there and it looks like plenty of clearance. Cut the base and portals/supports using an old B&D jigsaw.
The base is roughly 22 inches square (about the same as Rev-1).
Next steps are to (1) make the liner for the tunnel and get that cemented in place (still need to decide partial or end-to-end), (2) make a column out of a stack of one-by piled up to a height of six inches (same height as the supports) and cement that in place, and (3) cut a top. Once the top is in place, I can drill the hole for the tree to sit in and the second hole for the tree power cord. Lastly, will put a few screws in it to make sure the whole thing stays together.
Okay, I cut the cardstock liner bits and got those cemented in, then assembled the balance of the wooden substructure:
Top left is the basic structure with the liner installed, then a few views after the top and tree-holder column were installed.
I didn't quite get the curves right when I glued the liner panels in place (you can see some bowing in a couple of them). It shouldn't be an issue, just isn't the neatest job. I realized that the cardstock might prove to be translucent once the lights are turned on, so I added a couple of corrugated panels behind the inside curve walls to try to mitigate that. There is a gap on either side of the column for the tree-holder, and light will show through. No worries.
I still need to drill a hole for the tree's power cord to pass through, and I want to add a number of screws in the top to assure that it all stays together. There'll be a bit of stress in the top and tree-holder column when the tree is in place, and I don't want to risk it coming apart. The screws will tighten it up structurally.
The tree-holder column is slightly out of place, resulting in it protruding slightly into the tunnel. It's only about an eighth of an inch, so I'm hopeful it's not going to be a problem. If it is, I can file it down a bit with a rasp to correct the clearance. I won't know if I need to do that until we make a few test-runs (something I likely should have done before I glued the top and tree-holder into place).
A bit of progress this week, finding time in the evenings after things settle down a bit.
Got the hole drilled for the tree's power cord which can be run out the bottom and off the table to an extension cord. Digging around in the shop bit-box, found one of those desk cable-plugs that I can use to mask the hole a bit, then put a few screws in the top to strengthen it a bit. Easy-peezy...
So that leaves the scenic bit; we started cutting and cementing in the contours for the back side. I'm using some old USPS shipping boxes; that stuff is super-thin corrugated, super thin but strong. Cut and glued in the first three...probably 30-40 left to cut.
The opposite side (inside the curve) is a bit more complicated. I plan to include three or four small buildings over there, similar to what Lionel did on their 923 curved tunnel. Each building has the underside open so that a light can shine up into it, illuminating the windows. I think the 923 tunnel was made out of glue-soaked felt material. I can only imagine the mess that made, lol. I'm planning on using Papier-mâché, similar to the last time. This is the stuff that Elastolin used to make their tunnels.
Anyway, I don't have a good plan for exactly how I'm going to this, but I think it would be prudent to make the basic structure of the buildings first and then work on the contours which will accommodate them.
Here's a couple pics from this evening:
The first building will be putz-style representation of a hotel, the Buena Vista. Hoping to get the basic structure of that done this weekend. I think we'll make that a lift-out so we can use it to access the battery box for the light string that'll go inside (or whatever light source we come up with). An alternative would be to just tilt the whole structure and reach up inside, but that might be awkward once the tree is in place. Still noodling this.
Spent the weekend working on the three putz-style buildings for the tunnel project:
Still a ways to go, but once these are done I'll have a better sense of what will go where and I can start cutting the contour partitions for the inside of the curve.
