Simple tinplate project
Tinplate-inspired models and resources including lithographed patterns, building graphics, tips and tricks.
I've had a beat up American Flyer 3011 sand car in the parts bin for quite a while. My original intention was to either give it a refurb or simply strip it for usable parts. Instead, I decided to make a military flat car out of it.
First step was to remove the body from the frame. Pretty easy, just straighten up eight tabs and lift it off. Unlike the Lionel 902, the brake-wheel and stanchion on the 3013 is attached to the body only and doesn't pass through the frame. I'll save the body in case I decide at some point to reassemble the car. I have a source for a replacement brake-wheel should I decide to do that.
Next step was to remove the the bits from the frame. Wheels, axles, and journals are easy enough. The wheels and axles come out with just a minor flex of the frame. I used the Dremel and a wire wheel to polish off the coating of rust and shine them up a bit, then set them aside. The journals are each attached with a pair of tabs...just bend the bottom one straight and they are easily removed. I have an old can of Brasso that I used to shine them up. That and a buffing wheel on the Dremel has them looking pretty smart.
The tab/slot couplers are a different matter. Both are missing their tabs, whether they broke off sometime in the last 90 years or someone purposely removed them, not sure (although I don't know why someone would purposely remove them). I couldn't find replacements (didn't try too hard, I'll admit). No worries, I'm feeling lazy and slot-only will work as long as the next car in the string still has its tab(s). The other thing is these are riveted in, so you'd have to drill them out and re-rivet them to get them back on. Initially I intended to repaint the frame, but the original paint is in nice shape with just a few scratches so I'm going to leave that be. I used the Dremel and wire-wheel to polish up the couplers in place as best as I could.
The last step in this initial phase was to drill one additional hole for possible use in mounting the load. Easy enough; once that was done, I polished the frame with a bit of Turtle Wax polishing compound, then a bit of Meguiar's cleaning wax. Once that was done, I reinstalled the journals, wheels, and axles.
I ordered a number of 3D-printed items from a printer I've used a number of times for other stuff. Assembled one of the 3D-printed kits and gave it a paint job. At 1/56-scale, it's slightly small for O-gauge (1/48), but it's tinplate, so who cares:
A French FT-17 of WWI vintage, it probably should have some serial numbers on it, and maybe one of the playing-card platoon/section markings. I might go back and give it an overspray of Tamiya clear gloss...that might make it a bit more attuned to the tinplate look. I do think it has the look of some of the military-themed offerings of Marx, Marklin, and Elastolin during the interwar era.
Anyway, an easy project that found use for a battered old gondola.
Re: Simple tinplate project
We changed the project up a bit, restoring the Flyer gondola body to its frame after a repaint using some metallic red automobile paint. A bit of an experiment, the results were mixed. Despite stripping/cleaning the body thoroughly, the finish proved rather uneven, appearing blotchy in places. Likely should have used a primer of some sort, but I'm not going back and start over.
The "tank" car project moved to a Marx gondola frame, this from a battered 552 that had suffered some deep scratching and corrosion on one side. The frame/wheels/axles/couplers were all in good shape, however, so a perfect candidate. After removing the gondola body, I gave the black frame a respray of satin black after a bit of masking:
The tank got some reworking as well. I gave the paint scheme a bit of outlining similar to the "lozenge" schemes used by the French during the war, then an overspray of clear satin lacquer. I think this gives it more of a toy-like appearance, similar to the stuff Elastolin made during the interwar years.
A strip of styrene and a self-threading screw fastens the tank to the frame using the existing hole.
I don't have much Marx equipment in the collection, but I've always had interest in their military-themed trains and toys. This might be the start of something.
