HO-Sized Building photos
A Reader writes:
I found this page for building front photo and was wondering if they were available in 1:87 for HO. I would sure like to print some. I have about 12' of wall that is part of Reading Pennsylvania 1900 to 1950 that this could help me flesh out with some realism. I do HO only.
----------Our Response -------- You may add your own below ------------------
Thanks for getting in touch.
Regarding the printed building fronts, check out the Big Indoor Trains version. The celtic page has HO buildings already:
http://bigindoortrains.com/indoor_resou ... acades.htm
Yes, some of them look a little Irish, as they should.
On the page with the US buildings, I haven't made an HO version since the printer drivers used to allow you to print at 50%. Now some of them don't. I'm attaching two buildings that I resized using my printer utility. Please let me know if this size will do the job, and I'll try to get the rest to you later,
Best of luck - Paul
dillingers_h0_scale2.pdf
(2.32 MiB) Downloaded 2871 times
firehouse_h0_scale2.pdf
(3.33 MiB) Downloaded 2810 times
