Standard Gauge Photo Gallery
Discussions about the classic tinplate by Ives and other early manufactures.
Re: Standard Gauge Photo Gallery
Yup, the Lionel 68 looks sharp. Around the holidays I put one on the fireplace mantle...helps smoke out any toy-train buffs that visit the house.
A recent 'rescue' from the local antique mall...needs some work:
The refurbished trucks were recovered from an early Lionel piece...they should work here. I think I might repaint the roof at some point, but just clean up the body and interior.
Paul, what material did they use over the windows on the side? It looks like they're in good condition compared to many I've seen.
Paul - The top-side window material is a plastic film with a mottled white and blue treatment hand-applied to it. Reproduction machine-printed material is available but it is a bit thicker and less translucent then the original. If possible (and it usually is) one should try to recover the original material for re-use. Like the clear plastic window material, it is held in place by a few sharp-edged tabs.
When I get around to working on this car I'll need to add a pick-up to one of the trucks to provide current for the lighting. The earliest versions of these cars had no installed lights...they were lit by a string of lights that could be purchased separately and run through them from a connection on the locomotive. I've only ever seen one of those kits manufactured by Lionel. The 33 that I have has the connecting post but it is not wired into the loco.
Here's a pic of what the kit looks like:
An MTH reproduction of the Lionel 9E (with a Franklin Mint 1/24-scale Mercedes 300SL):
I often wonder what the correct "scale" is for Standard Gauge...somewhere beween 1/24-1/32 I suspect.
An MTH 9E reproduction polishes the rails beneath our 2017 Christmas tree:
A former shelf-queen, this loco needed a Protosound chip reset before we could get it running. It's a common problem with battery-backup Protosound units. At some point I'll go back and install rechargeable capacitors (BCR's) to this and my 392E, mitigating the problem.
Christmas 2018:
Lionel 33/35/36 set from 1925-1926. Despite a chunk missing from one of the drive-wheels and a few teeth from the pinion gear, still runs like a champ.
Looks about right...
Another shot of the Lionel 33 from a couple months back:
We'll work on getting the 10 back in running order for 2019.
Love these!
You do excellent restoration work
Picked up this Lionel 517 recently. Turns out it's a bit unusual for the two-tone paint and orange windows (although I swear I've seen a number of them).
Years ago I bought an MTH standard gauge freight set with a 392E up front with a string of brass-trimmed 500-series freights. For whatever reason, the dealer shipped me a 517 with the late all-red scheme with nickel trim. At the time I didn't throw a fit, but I came to hate the one out-of-sync car. This original 517 will be its replacement. Just a bit of polishing up and it'll be good to go.
Lionel 517
Lionel 517
Lionel 517 b.jpg (164.58 KiB) Viewed 121847 times
Lionel 517
Lionel 517
Lionel 517 a.jpg (159.81 KiB) Viewed 121847 times
